Old 12-28-2010, 08:19 PM   #1
willygoodness
Drives: 09 yaris hb
changing reversing bulbs and now other things don't work
Hi
I was changing my reverse lights the ingition on and gear in reverse. It took me a couple times to get the bulb in properly, got 1 of the bulbs in and now the aircon fan doesn't work, the reverse lights don't work and when i'm in reverse the indicators don't work but they do when the cars not in reverse
i've checked all the fuses in the engine bay and the fuse panel inside the car that i can find and they are all good.
any ideas on how to fix this problem?
09 3dr manual yr HB
willygoodness is offline   Reply With Quote
Old 12-30-2010, 07:41 AM   #2
willygoodness
Drives: 09 yaris hb
hummm.. does anyone know how to explain how to test relays?
cheers
Old 12-30-2010, 08:13 AM   #3
Did you install the correct bulbs? Are the replacements standard bulbs or LEDs?
Old 12-30-2010, 02:56 PM   #4
BLH
Drives: 2007 Yaris Sedan
So the power was On when you attempted to change the bulbs?
Old 01-01-2011, 08:18 PM   #5
willygoodness
Drives: 09 yaris hb
i had LEDs in there for a couple weeks. i was changing back to standard bulbs because the LEDs weren't quiet as good for visiblity when it was raining at night and yes there was power going to the bulbs while i was changing them. i only changed the rhs(drivers side) bulb when this boo boo happend.
cheers for reading
Old 01-07-2011, 09:14 PM   #6
willygoodness
Drives: 09 yaris hb
checked all the fuses with a test light instead of just looking at them... it was a blown fuse.
odd that so many things would run through 1 fuse.
owell :)
Old 03-22-2012, 02:53 PM   #7
mbera
Drives: black 2011 Yaris zen3
i have the same problem thanks what fuse was blown
mbera is offline   Reply With Quote
Old 03-22-2012, 06:34 PM   #8
willygoodness
Drives: 09 yaris hb
I think it was number 10 or 14 fuse on the inside fuse pannel. It was a 10a fuse for me
Old 03-27-2012, 07:43 PM   #9
DUQ
Drives: 2009 Yaris 5 door
The burnt fuse caused the relay to pull in thats why the reverse lights were on. And never replace your lamps with the power on, you got lucky this time.
DUQ is offline   Reply With Quote
Old 03-27-2012, 08:42 PM   #10
There is no relay in circuit for the backup lights. The 10A GAUGE fuse feeds them directly through the backup lamp switch.
Old 03-28-2012, 09:46 PM   #11
DUQ
