Old 10-10-2011, 01:59 PM   #14
dzcab
Drives: 2011 3Dr Hatch
You can test the relay with a multimeter and a 9 volt battery. If you put the 9 volt battery to the two coil contacts (see my line drawing below) the relay will click on. When it is on the contacts will close, so with a multimeter you can check between the two contacts. They should be open when the 9 volt battery is not on the coils and closed when it is.
- Contact
- Contact
|| Coil
When I do this what should the multimeter say or what setting should I put it on. I have never done this before and I have someone letting me use their multimeter.
Thanks
dzcab is offline   Reply With Quote
changing reversing bulbs and now other things don't work willygoodness DIY / Maintenance / Service 10 03-28-2012 09:46 PM
Gas Savings Tips That Don't Actually Work! MadMax Fuel Economy Forum 21 03-09-2011 09:25 AM
November: Big Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 14 12-12-2006 10:50 AM
TWM Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 9 08-28-2006 03:37 PM
TWM Short Shifter/Shift Knob Sale! TWM Performance Performance Modifications 0 07-17-2006 05:08 PM
