2ZR swap. DO IT! Ask how!
Thanks! I did a bit more searching and found that the cylinders are 75mm dia. and 8mm apart, so the spacing should be 83mm. Just need the opening dimensions and the bolt locations and I can get a CAD model rolling.
Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
So you need the inlet size and the bolt locations?
You think your Yaris is low and fitted LOLzzzzz |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Yaris Intake Manifold | richardholdener | Performance Modifications | 201 | 05-18-2009 11:58 AM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 08:03 PM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-13-2008 11:26 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
