![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Some more brainstorming ideas:
- Did you check the air filter? - Does it seem like you have enough exhaust gases coming out the tail pipe? So someone didn't shove something, like a potato, in there? - Ever have issues with water in your gas? It wouldn't hurt to get a fuel additive to clean the fuel injectors that ALSO takes care of possible water in the gas. I'd do this as it is a benefit across the board. - Maybe try cleaning the MAFS again? Double check the o-ring around the MAFS is flexible, and there are no leaks around it? - Check the grounds on the motor? Make sure you don't have a bad ground somewhere? - Clean the terminals on the battery with a wire brush. - Does the engine run rough even when you keep the clutch pedal pushed in? It's a long-shot.. That's all I got right now. With no codes, it could be so many different things. Check the things above, and hopefully something fixes it. |
#2 | |
![]() Drives: 2007 Yaris Sedan 1nz-fe Join Date: Oct 2011
Thanks |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| New 3 Door Yaris Pre Production Photos from the Australian International Motor Show | jeikz | Third Gen Yaris General Discussion | 5 | 06-27-2011 11:56 PM |
