Old 10-17-2011, 02:02 PM   #1
flg
Drives: Silver Toyota
Just visited Micro Car Mag... Interesting. I'll have to be ck'n it out samore later.
Enough OT. I'm interested in what the head intake port dimensions and spacing are also.
I'm currently working on an exhaust header for my Yaris and hope to have something everyone looking for street performance would be interested in also. Ultimate track perf is another deal, maybe I'll get there later. The original exhaust manifold is such a joke there is little need to modify anything else first. I like the idea of purchasing the Weapon R Intake and modifying it for the Yaris, if that's the way we have to do it. An intake is alot of work compared to a header. Tunning and testing will take a while. Actually the stock intake is quite nice just a little on the small/long runner side for high rpm performance.
These are the 2 most likely components to bring good butt dyno, street performance results without further mods forced intake and piggyback ECUs etc.. But, as you can see we are being left out the cold by manufacturers. A 1 3/8 tube 12inch primary pipe header as Megon and others produce is Buls$%^t. A NA intake like the weapon R is not the best either for the everyday driver balancing MPG and foot on the floor performance. Maybe I can fill the niche?
flg is offline   Reply With Quote
Old 10-23-2011, 10:36 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I found a document that listed the cylinder bore as 75mm, and the wall between cylinders as 8mm--making the cylinder pitch 83mm. As far as the opening dimensions, I still haven't heard anything back on either recent intake manifold thread. I'm hesitant to pull off my intake manifold since it's my DD, but I'm thinking about putting on my 1ZZ throttle body soon, so I may do it then.
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
