Old 10-18-2011, 12:42 PM   #1
Vinceb
Drives: 2008 5 Speed Sedan
O2 sensors on the exhaust, but they should throw a code.
I agree with Stove, TPS
Ground loop from some added after market components (stereo, Amp, Cap, alarm, remote start).
Have you kept up with maintenance ? oil changes ?
You said you changed the coil and the plugs - so they're properly gaped ? it's not one of those wierd BOSCH 4 tip things is it ? what brand did you put in ?
did you test or change the plug wires ? could be a faulty wire but again, should set a misfire code.
Fuel filter clogged ? - how many miles or KM are on the car ?
Is there a fuel rail pressure regulator on the Yaris ? - I've replaced this on a cavalier before.
loose wires connected to the ECM in the engine, or is the ECM damaged.
You could try disconnecting the battery and leaving the car to sit for a few hours, then reconnect and drive around for a bit, that will reset the computer, and it's worth a try.
Keep us posted.
Vinceb is offline   Reply With Quote
Old 10-19-2011, 02:03 PM   #2
Mr.Tmosh
Drives: 2007 Yaris Sedan 1nz-fe
Keep us posted.
Hello guys, I´m taking the car to the shop this weekend to check everything you´ve said. Grounds, TPS, fuel filter, etc.
The car is 57,xxx KM, the plugs I used are Autolite platinum , I already disconnected the battery to reset the computer, when on "RELEARN" mode I noticed that the revs went up to 3 or a bit higher , and would stay there for about 20 minutes droping and climbing like crazy. Later the car was normal.
Idling the car, revs stay between 1000 and 500 but after 5~7 min the revs drop almost instantly and that´s when the rattling and shaking begins. Even if I press on the gas pedal it struggles to climb the revs.
OK thanks guys, I´ll keep you posted.
Mr.Tmosh is offline   Reply With Quote
New 3 Door Yaris Pre Production Photos from the Australian International Motor Show jeikz Third Gen Yaris General Discussion 5 06-27-2011 11:56 PM
