Check to see if your hangers have more than one hole to use. You may have used the wrong ones and don't need to buy anything.
If you get aftermarket hangers, I like the urethane ones from Cobb and other companies.
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Another method is drive it till the bumper melts to the crispy crunchy and then with a pair of pliers remove the bad parts and then dremel the removed area to mimic the exhaust......
Just kidding.....the stock rubber hangers holding the new canister are too short,most any parts store ie Autozone....have them in assorted lengths,most times in the back and not on sales floor,jsut ask them at the counter. Use some lube like WD 40 and spray hanger and slip the old on off and then new one on,and canister will hang a little lower to clear the bumper. Also check your connection to the midpipe and make sure it is lined up good,mine was a pain to get to line up,dont think it ever has till I got the Nitto midpipe.....now it is sealed and straight and no clunking on the frame. |
#3 | |
![]() ![]() Drives: 2011 Super White 5 door hatch Join Date: Aug 2011
thanks for the help guys! |
| the fujitsubo wagolis exhaust is installed. | enviri | Performance Modifications | 4 | 02-15-2011 10:07 AM |
| Header + Mid-Pipe + Exhaust Installed | AlainMikli | Performance Modifications | 29 | 07-02-2009 02:47 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| Tanabe Concept G Exhaust Installed | Toddhata | Performance Modifications | 65 | 10-06-2006 06:19 PM |
