Old 06-27-2009, 05:09 AM   #1
AlainMikli
AlainMikli's Avatar
Header + Mid-Pipe + Exhaust Installed
WR 4-2-1 Header
Nitto Mid-Pipe
Greddy Ti-C axleback Exhaust
the header & mid-pipe is quite quiet, just like the stock one, I can't head any sound from them inside the car...I only can hear the intake & exhaust right now
now the car runs pretty smooth without 2 CATs...but the gas smelt very very bad tho
about the exhaust, really quiet when you compare the HUGE tip with the sound
Idel: same as stock (inside the car), low deep tone(outside the car)
under 3500rpm: still pretty quiet(inside the car)
over 3500rpm: started to become loud
forgot to took a picture at the rear...
p.s. any know how to bypass the O2 sensor in the mid-pipe? I'm still working on it
To do: Supercharger…
Old 06-27-2009, 05:12 AM   #2
Alain, I think you deserve an award for the most quickly upgraded Yaris here
For the O2 sensor in the midpipe, the common fix is to use a spacer (aka spark plug anti-fouler) or an elbow joint, Garm's got some of those available too, I believe.
BTW the exhaust smell is worst when the car has just been turned on and is in warmup mode (rich mixture) but it's not to bad once it's been running for a while.
Old 06-27-2009, 09:04 AM   #3
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
nice...had the same setup before...this boy is not phuckin around...great work kiddo..
Old 06-27-2009, 09:54 AM   #4
vten
Him,
you need to post a soundclips please
Old 06-27-2009, 11:31 AM   #5
CDavis7M
Drives: 1990 Supra Turbo
It looks like the midpipe and maybe the axle-back are the same diameter piping as stock. Is that true?
CDavis7M is offline   Reply With Quote
Old 06-27-2009, 12:16 PM   #6
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Nice bro ! I'm running similar set-up and yes it does smell pretty rich sometimes ,but hey gotta pay to play right lol.
Old 06-27-2009, 12:17 PM   #7
It's only a lil bit bigger, but less restrictive overall
Old 06-27-2009, 12:49 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Looking good! What's the piping diameter? How does it perform? TIA
Old 06-27-2009, 12:50 PM   #9
AlainMikli
AlainMikli's Avatar
thanks
because I almost have all the budget before I get the yaris
Originally Posted by vten View Post
Him,
ok, i'll try to have one later, both inside & outside the car
Old 06-27-2009, 12:55 PM   #10
AlainMikli
AlainMikli's Avatar
may be i'll VIP just like yours too, kidding
I can't warmup my car in my garage anymore, I've to pull it to the driveway first
Um...the diameter of header is a way bigger than the stock one(front & end), the front of the midpipe is almost 2", but the end is less than 1 3/4, the axle-back is the same as the end of the mid-pipe. so may be that's why doesn't sound too loud~
Old 06-27-2009, 01:12 PM   #11
wow, that is a CLEAN yaris....i dont know that mine was even that clean when i drove it off the lot
nice job on the upgrades though!
Old 06-27-2009, 01:51 PM   #12
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
no messing around when coming to modding the yaris. that's what i like to see!
Old 06-27-2009, 04:13 PM   #13
Split
Drives: 2008 Yaris Sedan
what's the quietest aftermarket axle back available for the yaris hatchback? is it the TRD? Or is there some Vitz one people can order? I bet that would sound incredible with this set-up.
Also, keep your factory mid-pipe because eventually the first resonator in your nitto mid-pipe will fail on you and start rattling. it cant handle the heat coming from the exhaust.. it ends up burning the packing material around it. At that point i'd probably just cut it out and weld in the factory catalytic converter there. If i was doing it all over again, that's what i'd do anyway.
Split is offline   Reply With Quote
Old 06-27-2009, 04:15 PM   #14
Split
Also i can't help but noticing your nitto mid pipe looks different than mine... on mine there is a resonator RIGHT after the o2 sensor which caused the car to idle rough. Looks like its been removed. I had mine cut out and it fixed my problem. looks like nitto figured this out and removed it.
Old 06-28-2009, 01:50 AM   #15
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
Maybe the TRD or Apexi WS II, if your looking for quiet. The Apexi WS is known for being very quiet.
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 06-28-2009, 03:21 AM   #16
1NZYaris1
1NZYaris1's Avatar
Wow , not only the fastest Upgraded Yaris award , but i would have too say the cleanest , , has it even touched the tarmac yet
Super clean and super hot
Old 06-28-2009, 04:24 AM   #17
Man, my friend just has the Ti-C axle-back, and it's pretty loud already. I guess I'll hear yours at the meet. hehehe.
Old 06-28-2009, 04:52 AM   #18
AlainMikli
AlainMikli's Avatar
I think mostly because the Ti-C for yaris can't remove the silencer....or may be I don't know how to take it off...it seems the silencer is welded to the tip itself.....
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
FS: Megan Racing Exhaust n Header. Sabretooth Items for Sale by private party 6 05-17-2009 05:04 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
Exhaust Pipe Size (Tamaño del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
