![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
Header + Mid-Pipe + Exhaust Installed
WR 4-2-1 Header
Nitto Mid-Pipe Greddy Ti-C axleback Exhaust the header & mid-pipe is quite quiet, just like the stock one, I can't head any sound from them inside the car...I only can hear the intake & exhaust right now ![]() now the car runs pretty smooth without 2 CATs...but the gas smelt very very bad tho ![]() about the exhaust, really quiet when you compare the HUGE tip with the sound Idel: same as stock (inside the car), low deep tone(outside the car) under 3500rpm: still pretty quiet(inside the car) over 3500rpm: started to become loud forgot to took a picture at the rear... ------------ p.s. any know how to bypass the O2 sensor in the mid-pipe? I'm still working on it
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… Last edited by AlainMikli; 06-27-2009 at 12:56 PM. |
Alain, I think you deserve an award for the most quickly upgraded Yaris here
![]() For the O2 sensor in the midpipe, the common fix is to use a spacer (aka spark plug anti-fouler) or an elbow joint, Garm's got some of those available too, I believe. BTW the exhaust smell is worst when the car has just been turned on and is in warmup mode (rich mixture) but it's not to bad once it's been running for a while.
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
nice...had the same setup before...this boy is not phuckin around...great work kiddo..
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
Him,
you need to post a soundclips please |
![]() ![]() Drives: 1990 Supra Turbo Join Date: May 2009
It looks like the midpipe and maybe the axle-back are the same diameter piping as stock. Is that true?
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Nice bro ! I'm running similar set-up and yes it does smell pretty rich sometimes ,but hey gotta pay to play right lol.
It's only a lil bit bigger, but less restrictive overall
Looking good! What's the piping diameter? How does it perform? TIA
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#9 | |
![]() because I almost have all the budget before I get the yaris ![]() ![]() ok, i'll try to have one later, both inside & outside the car ![]()
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
#10 | ||
![]() Quote:
![]() Um...the diameter of header is a way bigger than the stock one(front & end), the front of the midpipe is almost 2", but the end is less than 1 3/4, the axle-back is the same as the end of the mid-pipe. so may be that's why doesn't sound too loud~
wow, that is a CLEAN yaris....i dont know that mine was even that clean when i drove it off the lot
nice job on the upgrades though!
no messing around when coming to modding the yaris. that's what i like to see!
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
what's the quietest aftermarket axle back available for the yaris hatchback? is it the TRD? Or is there some Vitz one people can order? I bet that would sound incredible with this set-up.
Also, keep your factory mid-pipe because eventually the first resonator in your nitto mid-pipe will fail on you and start rattling. it cant handle the heat coming from the exhaust.. it ends up burning the packing material around it. At that point i'd probably just cut it out and weld in the factory catalytic converter there. If i was doing it all over again, that's what i'd do anyway. |
#14 |
Also i can't help but noticing your nitto mid pipe looks different than mine... on mine there is a resonator RIGHT after the o2 sensor which caused the car to idle rough. Looks like its been removed. I had mine cut out and it fixed my problem. looks like nitto figured this out and removed it.
#15 |
![]() ![]() Drives: 09 3dr (sold), 12 SE 5spd : ) Join Date: May 2009
Maybe the TRD or Apexi WS II, if your looking for quiet. The Apexi WS is known for being very quiet.
Its all about the MPG's !! |
#16 |
![]() Wow , not only the fastest Upgraded Yaris award , but i would have too say the cleanest , , has it even touched the tarmac yet Super clean and super hot ![]()
#17 |
Man, my friend just has the Ti-C axle-back, and it's pretty loud already. I guess I'll hear yours at the meet. hehehe.
#18 |
I think mostly because the Ti-C for yaris can't remove the silencer....or may be I don't know how to take it off...it seems the silencer is welded to the tip itself.....
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 05:26 PM |
| FS: Megan Racing Exhaust n Header. | Sabretooth | Items for Sale by private party | 6 | 05-17-2009 05:04 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| DC sports header installed. | largeorangefont | Performance Modifications | 41 | 09-20-2007 09:14 PM |
| Exhaust Pipe Size (Tamaño del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
