Old 06-27-2009, 05:13 PM   #13
Split
Drives: 2008 Yaris Sedan
what's the quietest aftermarket axle back available for the yaris hatchback? is it the TRD? Or is there some Vitz one people can order? I bet that would sound incredible with this set-up.
Also, keep your factory mid-pipe because eventually the first resonator in your nitto mid-pipe will fail on you and start rattling. it cant handle the heat coming from the exhaust.. it ends up burning the packing material around it. At that point i'd probably just cut it out and weld in the factory catalytic converter there. If i was doing it all over again, that's what i'd do anyway.
Split is offline   Reply With Quote
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 06:26 PM
FS: Megan Racing Exhaust n Header. Sabretooth Items for Sale by private party 6 05-17-2009 06:04 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 10:14 PM
Exhaust Pipe Size (Tamaño del tubo de escape) carlosh Central and South America 11 08-02-2007 05:15 PM
