Old 10-27-2011, 09:42 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
One way to test a wheel bearing is load it and unload it and see if there is a change in pitch. Like swerve left and see if it gets louder or right and see if it gets quieter IE like how you mentioned it went away turning right. So more than likely its going to be a left side wheel bearing. If you take a floor jack or dont own one you can use the one in the car. Lift up the left side of the car and firmly grasp the upper and lower portion of the wheel. And see if it will wobble up and down as well as left and right. If there is any play at all its safe to say this is the culprit. You can try spinning the wheel you may hear some rumbling noise as well. It is a safety issue as the wheel bearing becomes worse and totally destroyed it can cause the wheel to full lock up or worse fall off in worst case. But you would have to be totally ignorant and drive the car at high speeds with the loud humming for that to happen.
Old 10-27-2011, 10:06 PM   #2
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Yeah I tried that you can move it a bit from all angles. Looks like I will be bringing it in tomorrow to see if they can do this.
EDIT: I really don't want my wheel to fall off lol so I will be paying $$ to have this fixed ASAP as this is our only car at the moment.
devinlamothe is offline   Reply With Quote
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Installing Rear Wheel Bearing Hub brad4ds Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2011 06:34 PM
Front Wheel Bearing Failure craigq DIY / Maintenance / Service 4 08-17-2007 07:26 AM
