Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 11-01-2011, 06:01 AM   #1
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Very Low IDLE
may nakaranas na ba nito, parang under 800rpm ang idle ko kaya may nginig anybody experienced this?
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 11-01-2011, 06:04 AM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol ang normal idle naman ay talagang below 800rpm mga nasa 500rpm nga lang si storm ko at sa palagay ko ganun din sa mga ibang kayaris, if mababa pa sa 500rpm un ang may problema, cguro need to clean the intake..
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 11-01-2011, 07:25 AM   #3
charlieXX
Corporate Slave
charlieXX's Avatar
Tol si storm mo at 500rpm idle naka aircon ka hindi ba nanginginig??
Old 11-01-2011, 07:42 AM   #4
duke_afterdeath
hindi naman tol, sakto lang, lalo na pagbagong linis ang trottle fly
Old 11-01-2011, 09:39 AM   #5
syntax
syntax's Avatar
kapag napansin mo na taas baba ang rpm, that is the time na mag throttle fly cleaning, ang norm kasi sa rpm 500 to 650, bukas man or off ang A/C, HTH
Old 11-01-2011, 12:09 PM   #6
duke_afterdeath
+1..... sa friday subukan nating linisin yang throttle fly ni cutie,, start na ako mag hanap kung saan ko nalapag ung carb cleaner ko, kalilipat lang kasi marami pang naliligaw na gamit, hehe...
Old 11-01-2011, 12:40 PM   #7
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
+1 din ako sa magpapalinis, kailangan makita na yan duke!hehehe
jonimac is offline   Reply With Quote
Old 11-01-2011, 12:56 PM   #8
duke_afterdeath
ok tol umpisahan ko ng maghanap mamaya, hahaha
Old 11-01-2011, 09:01 AM   #9
charlieXX
Corporate Slave
charlieXX's Avatar
Throttle fly cleaning, paano mo ito ginagawa baklas ba or buga buga lang ng carb cleaner?
Old 11-01-2011, 09:36 AM   #10
syntax
syntax's Avatar
buga buga lang kami pre' mahirap magbaklas nun eh hehehehehe
Old 11-01-2011, 12:40 PM   #11
charlieXX
Corporate Slave
charlieXX's Avatar
@syntax and duke yes ganyan nga siya now akyat baba ang rpm niya pagka naka sindi or naka off man AC :-)
Old 11-01-2011, 12:58 PM   #12
duke_afterdeath
linisin natin sa friday tol
Old 11-01-2011, 01:24 PM   #13
syntax
syntax's Avatar
patak patak na lang sa 2 carb cleaner, para lahat tayo heheheheh
Old 11-01-2011, 02:36 PM   #14
duke_afterdeath
kapag hindi ko na lang makita saka tayo mag patakpatak, medyo madami pa un e...
Old 11-01-2011, 02:46 PM   #15
jonimac
jonimac's Avatar
sa SACO meron nun, nasa 15sr yata...besides 2 o 3 buga lang naman ginagawa ni bigboy pag nililinis yun.
Old 11-01-2011, 02:49 PM   #16
duke_afterdeath
aiwa..
Old 11-01-2011, 02:54 PM   #17
charlieXX
Corporate Slave
charlieXX's Avatar
okeee
Old 11-02-2011, 01:37 PM   #18
duke_afterdeath
carb cleaner found
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Low RPM when Idle Betrivent DIY / Maintenance / Service 12 03-03-2013 06:55 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
