![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
It depends on how you drive and your use of the brakes.
Obviously more rough and repeated use of the brakes will cause them to wear faster. |
#2 | |
I will add that it is not nessarily how often you use the brakes that wear them quicker but, how you uses them. If you frequently wait until the last second to apply the brakes and then apply hard pressure on the pedal, you will ware brakes out fast. What you have to do is gently apply the brakes sooner to gradually come to a stop without the need to apply heavy pedal pressure. Granted, this is not alway possible but, should be practiced as often as possible. It will make them last much longer. |
This ^^^^^. I also think having a manual transmission helps re making the most of this. I hear the old 'brakes are less expensive than an engine', but I'm getting many miles out of both and I don't rev the engine very high when downshifting during this scenario.
#4 | |
| Brakes Squealing! | cmkennedy | New England | 1 | 10-30-2011 06:08 PM |
| general service of brakes | TriumphAnt | DIY / Maintenance / Service | 10 | 08-07-2010 02:20 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 12:04 AM |
