Old 12-02-2011, 08:47 PM   #1
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Well if you were to use the ones form Micro Image you'd want the H4 Bi-xenon kit. Bi-xenon means that they contain both hi and lo beam in one bulb- which means that it will work with your stock light housing. Plug and play is subjective.. determined by the kit and how it's set up. If you're lucy you'll just plug the whole assembly into the bulb and it should work. If oyu're unlucky you may need to do some rewiring to the harness. No modifications to the car's electronics should be needed unless you have DRLs (Daytime running lights). If you have DRLS you may want to unplug the module so the HID's don't flicker. (DRLs give a smaller amount of power to the incandescent stock bulbs so they produce a dimmer light that can be used during the day to indicate your vehicle is on)
$120 AUS PER KIT XENON XTREME SLIM HID $120 JDMWAT Items for Sale by private party 0 03-02-2011 02:27 AM
Hid bi xenon problem need to keep drl due to fogs marcus Cosmetic Modifications (Exterior/Interior) 4 06-20-2010 12:01 PM
installed some 3000k HID's thebarber Photo-Video-Media Gallery 17 01-22-2010 09:45 AM
DRL and HID's? dimsum69 Cosmetic Modifications (Exterior/Interior) 5 01-12-2009 03:30 PM
xenon hid light bulb lilman717 Cosmetic Modifications (Exterior/Interior) 7 12-19-2008 08:07 PM
