Not quite a noob
as garm says it sounds like rubbing between the bar and maybe the bottom of the shock? Perhaps on of the bolts has come loose and there's play which sounds like a thump in the cabin.
#2 | |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I was going to check if the bolts were loose anyway, as i've read that you need to tighten them after you've driven the car for a little while after it's installed. The ones on the shocks were a little loose, I got them tightened up so i'm going to try and go for a drive this evening and see if that has solved it. ![]() Thanks for your help guys! |
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
| Sway bar link replacement | salmonz | DIY / Maintenance / Service | 8 | 12-09-2010 09:30 AM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 11:52 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
