Old 12-14-2011, 01:02 PM   #1
barryware
when the compressor is allowed to run based on the status of the A/C switch or the position of the air selector knob, it won't run for long anyway in the winter. The compressor runs and cycles on and off based on refrigerant pressure.
When it is cold out, the compressor may start but because the refrigerant pressure will be too low based on temperature to continue to run, it will shut itself off. I really do not see the need to disable the operation based on the position of the selector knob.
If it is warm enough, you may want the compressor to run and aid in defogging the windows. If it is cold enough and heat alone will do the job, the compressor isn't going to run anyway.
barryware is offline   Reply With Quote
Old 12-14-2011, 01:22 PM   #2
I find that even in below freezing temperatures that the compressor engages far more frequently than you would expect it to when running in defog mode.
Old 12-19-2011, 03:26 PM   #3
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
I'm glad bronsin posted to this thread recently. I hadn't seen it before. I just did the tab removal. It took just 10 minutes. I never liked the link of the defroster to the A/C. Thank you stran for posting the original hack (3 years ago).
rick996 is offline   Reply With Quote
Old 12-19-2011, 04:07 PM   #4
A-Dingo-Ate-My-Baby
Drives: yaris
I am not sure I understand this. My AC turns on with a button press.
2010 Yaris 5 door US spec with manual temp control knobs.
are you saying that the A/C turns on by itself in certain modes ?
my A/C light will only go on when I press the button
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-19-2011, 06:52 PM   #5
rick996
rick996's Avatar
Yes. Whenever you are in one of the 3 defrost modes (full or split). The light doen't come on. All modern cars that I know of do this. It makes the A/C last longer to run the A/C compressor once in a while during the winter. I will put the A/C on manually to accomplish this, but only when I am going down a long hill using DCFO.
Old 12-19-2011, 07:46 PM   #6
A-Dingo-Ate-My-Baby
Drives: yaris
holy crap you are right. I just tested it and watched the a/c engage
because I didn't really believe it, and the manual says 'if so equipped' and
since I got an almost rock bottom base model, I was convinced there were no
freebies here. the 4runner always goes to full a/c when you press defog but the
a/c lights up too...yaris doesn't light but compressor certainly starts
Old 01-01-2012, 01:56 PM   #7
swede
Drives: 07 SDN
I tried this mod today, I couldn't believe how easy it was to pull the dash apart to get to it. Everything just popped out and popped back in with ease, no screws or nothing. Just seemed a lot easier than previous cars that I've owned.
anyways I took some pictures and didn't find the wiper arm, maybe somebody can point it out to me. Hopefully the pictures will show it. I have a feeling that maybe I didn't go far enough.
1. Remove dash pieces
2. Pull AC knob out, be careful not to break the tabs
3. Pull backing off the unit, again be careful not to break the tabs
swede is offline   Reply With Quote
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 12:10 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Help Needed: Unlink A/C to Defroster stran DIY / Maintenance / Service 25 01-09-2009 01:50 PM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
