Old 12-14-2011, 09:29 PM   #1
If you pull the 7.5A one in the under the bottom of the dash panel, you will kill the AC ECU, but that will also prevent the rear window defogger and PTC heater from working.
The fuses under the hood are for the blower motor and the PTC heater.
So, to kill the AC for the winter and still have everything else work you would either have pull the connector from the compressor (and somehow seal both ends from the weather) or disconnect the green wire in pin 7 of the 16 pin connector on the AC ECU. That pin is the output to the AC compressor clutch.
Old 12-15-2011, 07:54 AM   #2
bronsin
bronsin's Avatar
Huh the manual just says AC for all three under the hood.
Which couldnt be true!
Old 12-15-2011, 08:17 AM   #3
Well, they are all for portions of the air conditioning system. And, that's correct above that the rear window defogger will work, but will lose its indicator.
Blown Fuse - Stereo !?! click.mine In Car Entertainment + Electronics (audio / video / alarm) 16 10-05-2017 08:35 AM
30A Power Fuse Instrument Panel Location? Kioshi DIY / Maintenance / Service 16 03-31-2013 06:53 PM
radio fuse Nodrog In Car Entertainment + Electronics (audio / video / alarm) 2 11-10-2011 06:10 PM
fuse box for fuse for brake lights drew999 General Yaris / Vitz Discussion 2 01-19-2010 02:38 PM
2009 empty, usable fuse location? schleppy In Car Entertainment + Electronics (audio / video / alarm) 3 04-23-2009 12:07 PM
