Old 12-16-2011, 04:48 PM   #13
barryware
My 1st replacement was a genuine OEM toyota pump.. 1st pump that came with new car lasted around 38k.. this pump never leaked but the shaft began to wobble and it was making all kinds of noise.
The 2nd OEM pump lasted till 73k.. So I am figuring that the oem pump is good for only about 35k+ miles. The last pump, I got at autozone for 1/2 the oem price. The gasket that comes with it was a POS.. just a piece of paper. However, that pump leaked from the get go. They gave me a replacement of the same type and that one is not leaking.
BMG is the maker if the pump I think.. Maybe I have the letters mixed up..
I may be mentioned that the belt was too tight causing the pump to fail prematurely. I can assure you that it was not the case.
barryware is offline   Reply With Quote
Tags
water pump changing
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
