Old 02-01-2014, 12:18 AM   #1
maui
Drives: 2008 Yaris hatchback in white
Water Pump Torque specs
thanks for those torque specs, I went with about 95 ft #'son the waterpump, no leaks should be good to go... BTW used almost exactly one gallon of Toyota Pink premix antifreeze just draining it out the bottom of radiator. The stuff looked perfectly clean and clear pink even after 115K but replaced it anyway...
maui is offline   Reply With Quote
Old 02-01-2014, 12:46 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
That is 8 lbs as in 8.1 lbs not 95 lbs ....snug thats all ...hope that is a typo on ur part at u mean 9.5 lbs hehe and ya it will take a jug of pink stuff just make sure u get all the air out of the system
Tags
water pump changing
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
