Old 12-19-2011, 01:05 PM   #1
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Originally Posted by jeff69dini View Post
thanks!!! hmm, any idea why one might suddenly jam while the door was partially open? I sorta put more force on it and it opened all the way
Before you spend any $ on it, try this:
Open the door all the way open. Might have to again use little pressure to open it all the way. Put some light oil (wd40) or the like on the bar portion of the stop check mech. Be sure to do the upper AND lower part of it. Close the door and open all the way repeatedly and most likely the movement will become easier. It sometimes gets "tight" when the mechanism does not travel over a spot often enough. (partially opening the dor all the time, vs opening the door all the way). I'll bet you "fix" the problem without lifitng a tool!
Good Luck!
bobolinko is offline   Reply With Quote
Door Handle LED DIY with pics window_lee DIY / Maintenance / Service 93 05-31-2012 11:58 PM
California May Ban Black Cars MadMax California 69 12-09-2009 10:44 PM
Black Door Armrests and A-piller Villen Cosmetic Modifications (Exterior/Interior) 1 07-20-2009 03:00 AM
Where can I get door edge protector? black rubber** Blenjar Cosmetic Modifications (Exterior/Interior) 5 03-13-2007 01:29 PM
Possible 4 door Yaris stateside? ElViShGiBbErIsH General Yaris / Vitz Discussion 19 05-18-2006 06:03 PM
