![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
I'm glad bronsin posted to this thread recently. I hadn't seen it before. I just did the tab removal. It took just 10 minutes. I never liked the link of the defroster to the A/C. Thank you stran for posting the original hack (3 years ago).
#2 | |
Drives: yaris Join Date: Jan 2011
I am not sure I understand this. My AC turns on with a button press. 2010 Yaris 5 door US spec with manual temp control knobs. are you saying that the A/C turns on by itself in certain modes ? my A/C light will only go on when I press the button |
Yes. Whenever you are in one of the 3 defrost modes (full or split). The light doen't come on. All modern cars that I know of do this. It makes the A/C last longer to run the A/C compressor once in a while during the winter. I will put the A/C on manually to accomplish this, but only when I am going down a long hill using DCFO.
#4 | |
because I didn't really believe it, and the manual says 'if so equipped' and since I got an almost rock bottom base model, I was convinced there were no freebies here. the 4runner always goes to full a/c when you press defog but the a/c lights up too...yaris doesn't light but compressor certainly starts |
![]() Drives: 07 SDN Join Date: Nov 2011
I tried this mod today, I couldn't believe how easy it was to pull the dash apart to get to it. Everything just popped out and popped back in with ease, no screws or nothing. Just seemed a lot easier than previous cars that I've owned.
anyways I took some pictures and didn't find the wiper arm, maybe somebody can point it out to me. Hopefully the pictures will show it. I have a feeling that maybe I didn't go far enough. 1. Remove dash pieces 2. Pull AC knob out, be careful not to break the tabs ![]() ![]() 3. Pull backing off the unit, again be careful not to break the tabs ![]()
here are some pictures of the micro switch. Didn't have AC in my last car and didn't have too much trouble without it, but I am still considering soldering it off instead of breaking it.
| Yarisworld.com DIY Manual v3 | vodkalush | DIY / Maintenance / Service | 101 | 06-25-2024 12:10 AM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| Gas mileage and A/C | Chaad32 | General Yaris / Vitz Discussion | 18 | 01-29-2009 04:31 PM |
| Help Needed: Unlink A/C to Defroster | stran | DIY / Maintenance / Service | 25 | 01-09-2009 01:50 PM |
| DIY Requests. | TinyGiant | DIY / Maintenance / Service | 13 | 10-29-2008 10:39 AM |
