Old 12-19-2011, 06:52 PM   #1
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
Originally Posted by A-Dingo-Ate-My-Baby View Post
2010 Yaris 5 door US spec with manual temp control knobs.
are you saying that the A/C turns on by itself in certain modes ?
my A/C light will only go on when I press the button
Yes. Whenever you are in one of the 3 defrost modes (full or split). The light doen't come on. All modern cars that I know of do this. It makes the A/C last longer to run the A/C compressor once in a while during the winter. I will put the A/C on manually to accomplish this, but only when I am going down a long hill using DCFO.
rick996 is offline   Reply With Quote
Old 12-19-2011, 07:46 PM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
holy crap you are right. I just tested it and watched the a/c engage
because I didn't really believe it, and the manual says 'if so equipped' and
since I got an almost rock bottom base model, I was convinced there were no
freebies here. the 4runner always goes to full a/c when you press defog but the
a/c lights up too...yaris doesn't light but compressor certainly starts
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 01-01-2012, 01:56 PM   #3
swede
Drives: 07 SDN
I tried this mod today, I couldn't believe how easy it was to pull the dash apart to get to it. Everything just popped out and popped back in with ease, no screws or nothing. Just seemed a lot easier than previous cars that I've owned.
anyways I took some pictures and didn't find the wiper arm, maybe somebody can point it out to me. Hopefully the pictures will show it. I have a feeling that maybe I didn't go far enough.
1. Remove dash pieces
2. Pull AC knob out, be careful not to break the tabs
3. Pull backing off the unit, again be careful not to break the tabs
swede is offline   Reply With Quote
Old 01-05-2012, 06:55 PM   #4
swede
Drives: 07 SDN
here are some pictures of the micro switch. Didn't have AC in my last car and didn't have too much trouble without it, but I am still considering soldering it off instead of breaking it.
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 12:10 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Help Needed: Unlink A/C to Defroster stran DIY / Maintenance / Service 25 01-09-2009 01:50 PM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
