Old 12-27-2011, 06:30 PM   #1
Viperoni
Drives: 2005 Toyota Echo
You would not HAVE to, but its not a bad idea if you can....
When I send 2kw over 20 feet in my HT setup, better believe I'm going to use Speakon connectors and 12g wire.
http://www.bcae1.com/images/swfs/spe...rassistant.swf
In the average 50w amplified car audio setup, you're fine with an 18g wire. If you're running off the deck, even less to worry about. It'd be a waste of money to worry about the wire when you could spend money on better speakers.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 01-16-2012, 08:45 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
That is the best car audio info site ever.... I've been referencing that place for the past 10 years.
Yeah, there will be no noticeable difference between the stock wires and larger speaker wires... in fact.... even on a 2000 watt system the difference between 18awg and 12awg will not be noticeable, and you will pay for it.... with that said, In the past I have ran as big as 8awg speaker wire in sub installs.
the issues really comes down to amperage versus voltage... speaker wire runs (from amplifier to speaker) are low amp/high voltage which does not require large gauge speaker wire. The power cable from a battery to an amplifier however uses low voltage - high amperage (needs big wire/cable).
amperage causes heat in wire much faster than voltage does. If the car world would get their crap together and change from 12volt to 48volt or higher we could run 2000watt systems off 10awg power cable instead of 0awg.
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Yaris T1 stock speaker upgrade CrzyCrg In Car Entertainment + Electronics (audio / video / alarm) 7 06-20-2010 06:02 AM
Using stock speaker as adapter pricerc In Car Entertainment + Electronics (audio / video / alarm) 4 03-28-2007 07:45 PM
question about stock stereo wiring? punch In Car Entertainment + Electronics (audio / video / alarm) 3 07-19-2006 03:22 PM
