Old 06-02-2010, 04:05 PM   #1
CrzyCrg
Drives: 2006 Yaris T1
Yaris T1 stock speaker upgrade
Ok, here's probably the most simple question you will get on this forum. I just bought a second hand T1 Yaris... Basically, all I want to do is upgrade the stock speakers... I was thinking Infinity splits up front and I have no clue what to do in the back. It's a 3 door model. All that I really want is a bit more bass and nice clarity without doing a full install. (i.e. amps, sub etc.) Any advice would be greatly appreciated especially tips on taking door panels etc apart. I've installed in golfs, hyundais, fords, but this is the first time on a Toyota!
Thanks!
CrzyCrg is offline   Reply With Quote
Old 06-02-2010, 07:15 PM   #2
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Check it out:
LB Rear speaker install
Removing door panels
Old 06-03-2010, 05:08 AM   #3
dushanm
dushanm's Avatar
Drives: Yaris T1
i have a T1, Can i install front and back door speaker split kits, will it effect the warrenty
dushanm is offline   Reply With Quote
Old 06-03-2010, 11:04 AM   #4
suckerface
#1 Lemming
suckerface's Avatar
AFAIK, installing aftermarket speakers should not have any affect on the warranty.
Old 06-04-2010, 06:36 PM   #5
CrzyCrg
Awesome! thanks! and then I'm now thinking of going with a 10" and a small amp just for a lil extra bass! i hope that it sounds good! any recommendations?
Old 06-09-2010, 02:09 PM   #6
CrzyCrg
ok, new plan! i want to do a Hertz?Audison install. After browsing the forums, it seems like that is a good way to go. I'm just worried about power consumption for the amps. will the 1 litre engine handle it?
Old 06-12-2010, 12:07 PM   #7
RedHatch08
Canadetroiter
RedHatch08's Avatar
Drives: 2008 3DR 5M
If you intend to use a small amp as you said, it should be fine.
If you are still worried about your charging system, you could always use a capacitor. Capacitors are great at taking the strain off of your car's charging system. Unlike a battery, they provide instant power to your amp for musical peaks like bass notes, because they charge and discharge very quickly.
The general guideline for capacitors is 1 farad per 1000 Watts. So if you have an amp with 500 Watts or less, a 0.5 farad capacitor should be fine. You could even use a 1 farad cap if you can't find a 0.5. You can't have too much capacitance.
K&N Air Filter . Rear Debadge
RedHatch08 is offline   Reply With Quote
Old 06-20-2010, 06:02 AM   #8
CrzyCrg
ok super! so with a bit of work, i should be able to get a 10" sub, a decent split up front and some good coax's to fill the rear? provided of course that i stay around 1000 watts.... tahnks for the help! with time i should be able to get the bits and pieces and do the install!
Rear speaker of the Yaris HB. zinou2009 Africa 2 07-09-2012 03:27 AM
whats the stock offset on yaris rs? marcus General Yaris / Vitz Discussion 2 04-16-2007 11:53 AM
