01-27-2012, 01:39 PM | #19 |
Yaris Hell
Drives: yaris Join Date: Jan 2012
I am referring to the chip swap how-to to replace the TB chip when upgrading.
I'LL KEEP MY GUNS AND MONEY, YOU KEEP YOUR "CHANGE"! |
01-27-2012, 02:25 PM | #20 | |
larger TB = more air = ECU sends more fuel = more power for the same a/f ratio. 1. drill out the rivets on both throttle bodies. 2. chip away the sealant from the idle adjust screw on the 1ZZ throttle body. 3. using small bolts and nuts, install the chip (black plastic assembly) from the Yaris onto the 1ZZ throttle body. 4. install the 1ZZ throttle body onto the Yaris, adjust idle screw |
01-27-2012, 02:30 PM | #21 | |
Yaris Hell
01-27-2012, 02:34 PM | #22 |
Yes, don't even TRY to do this with it still in place.
01-27-2012, 02:37 PM | #23 |
Yaris Hell
Yeah I got a really badly rounded-off nut I am gonna have to figure out before I can finish this then. Getting a CEL, and wanted to rule this out.
03-15-2012, 10:39 PM | #24 |
Drives: 2009 yaris sedan Join Date: Apr 2011
any guides on how to replace Front AND rear speakers on a 09 Sedan?
03-31-2013, 11:50 PM | #25 |
Drives: 08' white yaris lift Join Date: May 2012
ONE of the best DIY threads alive
05-19-2013, 09:15 PM | #26 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
The rear drum brake adjustment posts....one "had" pictures....doesn't "work" any longer....this would be quite helpful to have!. TIA
08-25-2013, 04:11 PM | #27 |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
I'm missing "automatic footwell lighting" ;)
Quite easy to get with maximum comfort, just attach e.g. LED-stripes to the seat frame and the plastic convers over the pedals and the same one on the passenger's side. Second, have a look at the rather small connector on the far left side of the fuse panel near the steering wheel where three rather thin wires arrive. The negative connector of e.g. the LEDs goes to the white wire with the black line on it, for the positive one you could just hook it to the purple wire, but for maximum comfort, I'd recommend a switch with a configuration that's called "on-off-on" if I remember correctly. There, the second pole should be connected to the blue wire. I have no pictures of this yet because I haven't had the time yet to apply this mod. As soon as it runs fine, I'll post a tiny circuit that turns on the interior light only in the dark when it's necessary, thus avoiding unnecessary battery drain :) By now, a somewhat larger project including Arduino, CAN Bus and DMX occupies me - might be finished tomorrow, next month or never ;) |
12-16-2013, 07:14 PM | #28 |
Drives: 2011 yaris Join Date: Dec 2013
Help
My red light for 2011 yaris came on sporadically what could be the reasons why? Help!!
12-16-2013, 07:33 PM | #29 |
What red light?
02-23-2014, 10:25 PM | #30 |
Tw200--excellent!
Revive this thread Yaris folk.
08-21-2014, 03:36 PM | #31 |
Drives: yaris, 5 door, 2007 Join Date: Aug 2014
center heater vent repair
There's no airflow from my center heater vents of my 2007 5 door yaris. Where can i find removal and troubleshooting instructions?
Chris |
08-21-2014, 03:44 PM | #32 |
No airflow from my center heater/ac vents
There's no airflow out of the center heater/ac vents on my center console. Where can I get a description of the vent system and /or how to trouble shoot the problem?
Chris |
08-21-2014, 05:27 PM | #33 | |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
http://www.microimageonline.com/foru...32-YARIS-FILES
11-01-2014, 12:31 AM | #34 |
Drives: 2007 Yaris Hatch Join Date: Feb 2007
Sedan rear speaker replacement?
11-01-2014, 07:50 AM | #35 |
Look at the "Audio Visual" section of the service manual, posted in the link above yours.
08-12-2015, 02:17 PM | #36 |
Drives: yaris TS 1.8 133cv Join Date: Sep 2011
This link:
Install HIDs - http://www.yarisworld.com/forums/sho...&postcount=114 doesn't work (error 404). Can anyone post the right link? |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. | Idjiit | Off-topic / Other Cars / Everything else Discussions | 6 | 10-06-2017 05:10 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
