Old 01-27-2012, 02:39 PM   #1
ayuhuasca
Yaris Hell
ayuhuasca's Avatar
Drives: yaris
The who? Are you referring to a reflashing?
I am referring to the chip swap how-to to replace the TB chip when upgrading.
I'LL KEEP MY GUNS AND MONEY, YOU KEEP YOUR "CHANGE"!
ayuhuasca is offline   Reply With Quote
Old 01-27-2012, 03:25 PM   #2
Via Micro Image...
larger TB = more air = ECU sends more fuel = more power for the same a/f ratio.
1. drill out the rivets on both throttle bodies.
2. chip away the sealant from the idle adjust screw on the 1ZZ throttle body.
3. using small bolts and nuts, install the chip (black plastic assembly) from the Yaris onto the 1ZZ throttle body.
4. install the 1ZZ throttle body onto the Yaris, adjust idle screw
Old 01-27-2012, 03:30 PM   #3
ayuhuasca
Yaris Hell
ayuhuasca's Avatar
Drives: yaris
Via Micro Image...
Thanks, do I have to take the TB out to get to the chip? Its already in there and I have the chip ready, just need to do as you mentioned.
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. Idjiit Off-topic / Other Cars / Everything else Discussions 6 10-06-2017 06:10 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
