Old 01-27-2012, 03:21 PM   #1
stuart_f
Drives: Yaris TR 1.33CVT
For those that have the cruise control, does the control stalk come out of a small flap on the back of the wheel? As seen in this pic.
If it does, is there an alternative cut-out that goes in place of the blanking piece at the base of the stalk?
Pictures of a standard install would be awesome :P
Reason for asking is that if I go ahead with the OEM install on a European Yaris where cruise is not an option, I'd want to buy the correct blanking plate to finish the job properly.
stuart_f is offline   Reply With Quote
Old 01-27-2012, 04:27 PM   #2
Some of the 3rd generation European Yaris are available with cruise control. I am not sure in what countries though. The same OEM cruise control stalk that worked for the US/Canada Yaris from 2006 to 2011 works with the 3rd generation European Yaris. I shipped a couple of cruise control stalks to a person from South Africa that had a French built 2012 and he was able to install it and immediately have cruise control. His Yaris did also have the instrument cluster with the cruise control symbols built in (shining a flashlight over the cluster let him see before hand that the symbols were there and as soon as he installed the stalk they lit up when cruise was turned on).
Another person on here, I believe from Finland, checked on his and his cluster did not have the symbols.
The plastic piece that gets replaced when cruise control is installed is called the Cover, Steering Wheel, Lower No. 2. The part number for the one with the hole in it is: 45186-0D030-C0
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Cruise control switch $20, 2007 OEM steelies w/hubcaps $70 2006fronty Items for Sale by private party 3 05-14-2010 02:40 PM
2007 Liftback with Brand New Wheels and Tires. Mead Cars for Sale by private party 0 02-12-2010 04:50 PM
Cruise Control bigapl DIY / Maintenance / Service 3 11-05-2009 10:52 PM
