![]() ![]() Drives: Yaris 3dr Hatch/Black Join Date: Feb 2006
Are SE owners getting their wheels and cruise control . . .
included as part of the package price? I live in Gulf States district and it seems the cruise is an option outside the SE package and wheels too.
They pull some bad stuff. Just curious.
![]() ![]() Drives: '89 Jetta, '07 Rabbit Join Date: Jan 2012
SE is inclusive of wheels and cruise control (among other things). The dealer you are speaking with must not be looking at the SE trim level or something.
![]() ![]() Drives: 07 Yaris 3Dr HB Join Date: Oct 2011
Direct the saleman to the Toyota web site where it CLEARLY states that the SE comes with cruise and 16" alloy wheels.
It is also in the brochure on the shelf at the dealership.
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
mine came with the alloys and cruise.
![]() Drives: Yaris TR 1.33CVT Join Date: Jan 2012
For those that have the cruise control, does the control stalk come out of a small flap on the back of the wheel? As seen in this pic.
![]() If it does, is there an alternative cut-out that goes in place of the blanking piece at the base of the stalk? Pictures of a standard install would be awesome :P Reason for asking is that if I go ahead with the OEM install on a European Yaris where cruise is not an option, I'd want to buy the correct blanking plate to finish the job properly. |
Awesome!
its on the steering wheel, i can get pictures later, the cruise is a lever assembly that moves rather that the 3 button tree branch that doesn't move in previous years.
#8 | |
Some of the 3rd generation European Yaris are available with cruise control. I am not sure in what countries though. The same OEM cruise control stalk that worked for the US/Canada Yaris from 2006 to 2011 works with the 3rd generation European Yaris. I shipped a couple of cruise control stalks to a person from South Africa that had a French built 2012 and he was able to install it and immediately have cruise control. His Yaris did also have the instrument cluster with the cruise control symbols built in (shining a flashlight over the cluster let him see before hand that the symbols were there and as soon as he installed the stalk they lit up when cruise was turned on). Another person on here, I believe from Finland, checked on his and his cluster did not have the symbols. The plastic piece that gets replaced when cruise control is installed is called the Cover, Steering Wheel, Lower No. 2. The part number for the one with the hole in it is: 45186-0D030-C0
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| Cruise control switch $20, 2007 OEM steelies w/hubcaps $70 | 2006fronty | Items for Sale by private party | 3 | 05-14-2010 02:40 PM |
| 2007 Liftback with Brand New Wheels and Tires. | Mead | Cars for Sale by private party | 0 | 02-12-2010 04:50 PM |
| Cruise Control | bigapl | DIY / Maintenance / Service | 3 | 11-05-2009 10:52 PM |
