Old 08-10-2013, 06:59 AM   #1
william7
Drives: Yaris 2012 Luna 1.0 L
I change my Yaris 2012 HB radio to the Toyota Touch receiver.
I have oem Yaris rear camera but the problem is wiring harness. My version of Yaris doesn't have the wirings for rear camera.
CTScott send me a diagram for audio in French made Yaris.
I understand that the wires go to connector F117 (F117 connect to the left top plug of receiver).
Can I take the power from reverse light and connect only video power and ground to receiver?
What mean CA+, CB+ on the diagram?
william7 is offline   Reply With Quote
Old 08-10-2013, 07:08 AM   #2
You could power it separate of the radio, but the CA+ to CB+ is the positive power output to the camera by the radio, where it only powers the camera when it needs to.
Old 08-10-2013, 07:39 AM   #3
william7
So +12V for camera is pin 7, ground pin 15. Right?
Where I can buy the F117 connector? I have no 16 pin connector in my radio wiring harness.
Edit:
I take reverse gear and check 7 pin and no power...
Old 10-03-2014, 03:20 PM   #4
ucsmfu
Drives: yaris le
I have a 2012 Canadian Yaris Le. Was wondering JayGee did the Crown camera fit ?
I was looking into this one http://www.ebay.com/itm/Car-Reverse-...0cd598&vxp=mtr
Also, our 2012 models didn't come with any navigation option so I am thinking of wiring it up to those rearview mirror/screen built in ones like this one
http://www.ebay.com/itm/Auto-dim-mir...3f0fc5&vxp=mtr
Let me know what you guys think.
Thanks
ucsmfu is offline   Reply With Quote
Old 10-04-2014, 09:27 AM   #5
2009D4d
Drives: 2014 Yaris Icon + 1.4D4D
Try here, may be of use: http://www.toyota-tech.eu/aimuploads..._003_187_0.pdf
2009D4d is offline   Reply With Quote
Old 10-04-2014, 10:47 AM   #6
ucsmfu
Drives: yaris le
Originally Posted by 2009D4d View Post
Thanks, however, my yaris doesn't have a built in head unit display :(
So I don't think the connector plug will work :(
Old 07-22-2015, 09:40 AM   #7
OGHUGO
Drives: 2015 Yaris 5 Door Hatchback
Update on the camera I purchased.. OK so I got the camera and no it does not fit properly it is not even long enough to reach the outside where the opening is on the plastic molding. So I tried to get another one that has a longer neck. Here is the ebay auction if you guys are interested.
http://www.ebay.com/itm/171593321191...%3AMEBIDX%3AIT
I will see if that works. and let you guys know.
What is the part number for the stock rear view camera and how much will it cost from the dealership any one know?
OGHUGO is offline   Reply With Quote
Old 07-22-2015, 11:51 AM   #8
OGHUGO
OK, while I wait for the new camera to arrive I wanted to start wiring my in the stuff I will need. Does anyone know where the wire for the reverse light is? Need to tap in to that for the head unit to properly display the camera when in revers.
Thanks in advance.
Old 07-22-2015, 10:26 PM   #9
ucsmfu
Drives: yaris le
Thanks in advance.
this was the one I got and it was a perfect fit
http://www.aliexpress.com/item/SONY-...536788227.html
This is the harness I bought and it worked well as well.
http://www.autoharnesshouse.com/19867.html
Very easy to install
http://www.autoharnesshouse.com/1/pr...amera_conn.jpg
Everything is plug and play except the reverse trigger wire where you have to plug in to the 28 pin connector on the back of your head unit and splice it to the reverse wire either on your ECU or reverse lights.
http://www.autoharnesshouse.com/19867_add.html
Let me know if you have anymore questions.
Old 07-23-2015, 03:51 AM   #10
OGHUGO
Man thanks for the info, however how is it that the camera you got was a perfect fit? did you leave the hole in the car after the install? that looks like it will just fit on the molding but doesn't seem like it will cover up the home that is left on the actual door. I want something that is going to go bolted on the 2 bolts and goes straight outside sortha like the actual factory one with out having to pay factory prices.
Also where is the wire for the ecu that I need to tap into?
Thanks again.
Old 07-23-2015, 05:36 AM   #11
ucsmfu
Drives: yaris le
Thanks again.
I'll take pics for you tomorrow, it is a perfect fit, eventhough it doesn't mount on the two screws, it's a perfect fit and won't fall out.
I didn't tap to ecu because I didn't wanna mess around with it, tapped the reverse trigger wire to the reverse light red wire :)
Old 12-28-2017, 09:56 AM   #12
logoris
Drives: 2017 Yaris SE Blue Streak
That is exactly what I needed, iv been looking for an adapter.
should this work on the 2017 se?
I have a camera already similar to the beatsonic style just to get it plugged in,
will standard cameras work? or will the view be off as it off to the side?
logoris is offline   Reply With Quote
Old 12-28-2017, 03:28 PM   #13
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Here's the camera I fitted. It was listed on eBay as fitting a Camry. It plugged into the hole from outside. It needed sealant around it as it is smaller that the opening (same width but can slide forward and back).
Also a pic of the view from the camera of my other car behind the Yaris in the driveway.
Old 07-26-2015, 08:30 PM   #14
OGHUGO
Ok, so i got the other camera and no go still does not fit. now its like $65 for the cost of both cameras and no go. I talked to the seller and he said he can refund if I return them but have to pay for shipping to china.. I have given up on trying to find one that is like the oem and got one like the one you got UCSMFU but got it from a us seller for $23 rather wait a few days than a couple of weeks.
Now I have everything ran all cables but need to get the right cable for the reverse trigger. Does someone have pics of where this is located?
Thanks.
Old 07-26-2015, 09:13 PM   #15
ucsmfu
Drives: yaris le
Thanks.
yes Eduardo did, wired it up to the ECU
http://www.yarisworld.com/forums/showthread.php?t=52850
Old 07-28-2015, 05:21 AM   #16
OGHUGO
Is that below the steering wheel column? I did not see that on the side.
Also tried to remove the covers and they hard as shit to remove.
Old 07-28-2015, 10:34 PM   #17
ucsmfu
Drives: yaris le
yes on the left side bottom, above the foot rest.
Old 12-27-2017, 09:12 PM   #18
chaditotx
Drives: 2007 3dr hb 5sp
I have a 2012 Se with retrofitted touch screen and nav. I bought the camera 86790-0D010 used from a parts house in Ireland. It just arrived, but I am trying to find the pigtail that goes from the camera to the hatch wiring. My wiring looks exactly as above. I can't seem to find the pigtail anywhere, or the wiring diagram for the hookup. Yes, I realize this is an old thread LOL
chaditotx is offline   Reply With Quote
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 07:47 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
