Old 07-22-2015, 10:26 PM   #29
ucsmfu
Drives: yaris le
Originally Posted by OGHUGO View Post
OK, while I wait for the new camera to arrive I wanted to start wiring my in the stuff I will need. Does anyone know where the wire for the reverse light is? Need to tap in to that for the head unit to properly display the camera when in revers.
Thanks in advance.
this was the one I got and it was a perfect fit
http://www.aliexpress.com/item/SONY-...536788227.html
This is the harness I bought and it worked well as well.
http://www.autoharnesshouse.com/19867.html
Very easy to install
http://www.autoharnesshouse.com/1/pr...amera_conn.jpg
Everything is plug and play except the reverse trigger wire where you have to plug in to the 28 pin connector on the back of your head unit and splice it to the reverse wire either on your ECU or reverse lights.
http://www.autoharnesshouse.com/19867_add.html
Let me know if you have anymore questions.
ucsmfu is offline   Reply With Quote
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 07:47 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
