Old 02-16-2012, 09:58 PM   #31
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
Originally Posted by pimp my yaris View Post
I am still using the stock fuel rail and stock fuel line and pick up assembly in the tank. With some modification I fit a longer 255lph pump into the pick up assembly.
So if Im right you say that you kept the whole setup except the fuel pump itself. I though that changing fuel pump for a walbro would require a "with return" type fuel system, so it mean New Fuel Reg and a Fitting in fuel rail. Correct me if Im wrong :)
I know we offer a fuel rail, might be Golden Eagle (very good brand).
Yes? So you have a fuel rail listed to fit my 1nz without modification, brand named Gold Eagle? What kind of price? The major problem with OBX rail (first I dont like the brand) is that completly installed, the location of the new rail doesnt sit directly in the good position. So my injectors are not well "seated" in, bolts tight you can easely play with the injectors. He looks like 1/4inch away from good position in the rail. A fuel rail is fairly simple to install, when getting the stock back on you really feel the injectors seat into the rail as you tight up the bolts.
maxthehax is offline   Reply With Quote
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
OEM Shock Durability darkmoon87 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-06-2010 01:38 PM
Yaris engine durability?? Hakan General Yaris / Vitz Discussion 42 11-15-2009 10:06 PM
lightweight rim durability fat like reflexes Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 09-25-2007 09:07 AM
yaris durability stuffy General Yaris / Vitz Discussion 3 05-05-2006 07:16 PM
