Old 07-18-2011, 07:34 PM   #37
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Still at 10psi and going strong.
Old 07-19-2011, 09:59 PM   #38
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
This month marks 2 years the Ptuning spec ss block has been in my car... it has been raced since the 1st weekend and driven every day. Now running 27psi as of last week.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 07-20-2011, 06:09 PM   #39
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
27 psi! What are you running diesel in that thing now LMAO
Old 07-20-2011, 10:43 PM   #40
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
lol. dont tractor pull tractors run like 100psi?
Still pump gas w/wmi. We are doing an e85 test tune next week. Another note, took car to local 1/8 mile today... traps 94mph in the 1/8 so my new quarter time should be 12.0 @ 119. Ill confirm soon enough.
Ptuning.com
Old 07-20-2011, 10:47 PM   #41
Bluevitz-rs
that's just re-donk-you-luss
Old 07-21-2011, 08:36 PM   #42
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
9psi waiting for cooler weather for a dyno run. Aem fic w/2az injectors and 255lph pump. Boosted for 10 months now
pimp my yaris is offline   Reply With Quote
Old 07-21-2011, 11:18 PM   #43
Focus_Sh1ft
Focus_Sh1ft's Avatar
27 psi is just plain filthy lol....
Old 09-15-2011, 10:53 PM   #44
Yoda
Yoda's Avatar
Might have finally broke it @12 psi spike. Went to go in third and missed, loud bang and felt like i hit a wall. Vacuum is bouncing around and i can hear some grinding. Gonna check it out some more in the days time. Might just have a small vacuum leak. Gonna get a compression test also to see where i am at after all this time.
I have been beating it into the ground for the last 3 months while I saved up 4k for a rebuild. I think it might still not be enough sigh...
Old 09-15-2011, 11:01 PM   #45
Bluevitz-rs
Ooooooo that sucks.
ok you missed like it didn't go into gear or missed like you got it into gear with a whole lot of grinding?
Old 09-16-2011, 10:10 AM   #46
Yoda
Yoda's Avatar
So good news 175 all across n this is me running it at 10psi hard. Gotta check to see if the turbo is still good tho. Need oil catch can and a retune and I will see what new numbers I will have for u guys. I am way over due for a clutch upgrade also. Can't shift into third if I am pushing it. Hoping that it just needs a flush and not the same problem that I had last time. O and Pimp get you car on a Dyno man!
Old 09-17-2011, 11:33 AM   #47
Focus_Sh1ft
Healthy compression after 3 months of beating on it at 10 psi? That's great news man... Maybe 10 psi will become the new 8 psi?
Seriously though, I think I speak for everyone when I say I appreciate what you're doing with your car. This will give us great information on how much a 1NZ can take before it finally craps out.
Old 09-18-2011, 08:53 AM   #48
pimp my yaris
C'est la vie
I had some problems with the car dying out when going to neutral from high boost after the blow of valve pops. I am working on a recirculating hose for blow off gases. So far it is working good. Just need to improve the design a little. The colder weather is giving me some stout power. Much better then the 90 degree shit.
Old 09-19-2011, 05:29 AM   #49
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Forgot to post on here my new tune:
We got the 1NZFE running 211Bhp @ 6500rpm / 184Torque @ 4850rpm @ 9psi on a GT2560R.
To refresh memory stock: head bolts / OEM gasket / Complete OEM head (no porting)
Presently I am re-wiring the AEM boostsolenoid to the Haltech Ecu and pump it up till 14psi boost on pump gas + octane booster.
Parmas is offline   Reply With Quote
Old 09-30-2011, 08:04 PM   #50
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
Easy lol... Thats all i know....My truck was 720 at the wheels last dyno that was on...I just wish the 11.94 was a little lower but 8 bent rods changed my tone. Now time for a built engine with that big single charger hummin on top
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 01-21-2012, 06:14 PM   #51
Yoda
Yoda's Avatar
Had a rough idle problem for the last month and couldn't figure it out. Tried everything now I am looking at the engine. Will post result later on.
Old 01-21-2012, 06:59 PM   #52
Yoda
Yoda's Avatar
So hears the run down
Compression:
Cyl1 145
Cyl2 165
Cyl3 170
Cyl4 185
Cause was burnt exhaust valve
Injector on cyl1 was dirty and it was runnin a bit lean burnt up the valve.
So now its really time for a rebuild .
Need to source an engine for a good price. <<<< Garm...Carlos...
Plans are to get to 250whp.Still sitting on that 4k to get things started. Need help getting my parts list together.
Now its time for input I did my part with logging the info.
Old 01-21-2012, 09:16 PM   #53
I have a complete and a short block in stock.
Old 01-21-2012, 10:40 PM   #54
TURBO YARIS
Drives: Yaris
Compression:
Cyl1 145
Cyl2 165
Cyl3 170
Cyl4 185
Now its time for input it did my part with logging the info.
I still have spare engine available, PM me.....
TURBO YARIS is offline   Reply With Quote
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
OEM Shock Durability darkmoon87 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-06-2010 01:38 PM
Yaris engine durability?? Hakan General Yaris / Vitz Discussion 42 11-15-2009 10:06 PM
lightweight rim durability fat like reflexes Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 09-25-2007 09:07 AM
yaris durability stuffy General Yaris / Vitz Discussion 3 05-05-2006 07:16 PM
