For the tire pressure monitoring ECU, the part number is 89769-52030 (and it is Yaris specific).
For the sensors, the part number is: 42607-33011 and they are the same ones used in just about every Toyota model from 06 on. As for Vten's question, the TPMS ECU can only be programmed with one set of four sensors, so to switch to a second set would require reprogramming.
| xD TPMS ECU interchangeable? | sex | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 11-07-2011 10:38 PM |
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 02:00 PM |
| DIY - - -TPMS work around | rningonfumes | DIY / Maintenance / Service | 6 | 03-03-2011 08:11 PM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 09:33 AM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 12:18 AM |
