Old 11-07-2011, 08:11 PM   #1
sex
sex's Avatar
Drives: 09 5DR
Question xD TPMS ECU interchangeable?
Thinking about a putting TPMS in a winter wheels setup. After looking at the EWD for both the Yaris and xD, it seems the xD module has an extra wire unused by the Yaris. Plugs look physically compatible.
So, anyone with access to an xD kind enough to test out whether or not:
1. the xD module will connect and
2. once connected, will it work?
Yes, it's a lot of trouble but my local junkyards have xDs but no yaris TPMS ECUs..
Old 11-07-2011, 09:00 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
I know the XD has a reset button under the driver's side dash...that might be what that wire is for...
Old 11-07-2011, 10:38 PM   #3
The XD's TPWS receiver and ECU both have different part numbers than the Yaris ones, so I don't believe that the XD parts are swappable.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 08:11 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
