![]() Drives: 2012 Blazing Blue Yaris(Auto) Join Date: Dec 2011
Removal + painting?
Is there any videos or instructions with pictures of people removing the Toyota emblem from the front and the back?
I want to paint them flat black and then put them back on, but I don't know if they are just on with double sided 3m tape or something else. Thanks! |
![]() ![]() Drives: Gen3 Yaris ZR Manual Join Date: Jan 2012
There's a couple of clips on the inside as well as the double sided tape. Remove the trim from the back door/hatch to get access.
![]() ![]() ![]() Drives: '12 Yaris LE Lagoon Blue Mica Join Date: Feb 2012
Before you paint them you must sand and prep them,so the paint adheres to the emblems.
#4 | |
Prior years, the front emblem is four clips only. No tape. The rear emblem is tape only. No clips.
Cool thanks for the tips! Keep them coming!
I will check it out later ^_^ |
![]() ![]() ![]() Drives: 2012 toyota yaris Join Date: Jan 2012
there is new method that a friend of mine told me about, its called plasti dip. he just recently tryed it on his IS250 and loved the results. after spraying on you can just easily peel off the excess paint with no problem. i might be trying that myself soon.
2012 yaris L model 2014 wrangler unlimited sport |
![]() Drives: Toyota Vios 2009 Join Date: Sep 2012
nice tips
EcoFriendly
Drives: 2007 Vitz HB Join Date: Sep 2012
also isopropyl alcohol is a great solution for cleaning the surface and emblem....
A member from Corpus Christi,Texas just did his rims in a sort of orange color. Another member in the U.K did his in black. Search plastidip and plasti dip with the search fuction. One of these hits includes a link to a YouTube video about the sublect with many similar videos listed on the right once you are onto that YouTube page. i'm sure your friend will clue you in re how to do it (if he hasn't already), but these other posts and venues will give you an idea what different aftermarket wheels look like with different dip color combinations and different car colors.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
The front emblem is deeper now and clips are a little different but it is still 4 clips on back
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
Check the last two links on my signature... some good pointers in there!
Plus on the 2012 there is an extra piece of impact abs between the radiator and the front bumper at the top where the emblem is....
![]() ![]() Drives: 2011 Toyota Yaris Join Date: Jan 2011
Clips on 2011 rear emblem?
On my 2011 does the rear emblem have clips or no? What is easiest way to remove? Just pry it off?
I can see this is not going to go well.
#14 |
Everybody!
Search is your friend. DIY: Debadge/Black out Emblems A quick synopsis: 2006-2011: Front: 4 plastic tabs hold it the the bumper2012+: Front: 4 slightly different plastic tabs hold it the the bumper
#15 |
![]() Drives: 2012 Yaris Trend Join Date: Aug 2012
Use plastidip, don't even have to take them off the car :)
#16 |
![]() ![]() Drives: '13 Super White SE Join Date: Apr 2012
| Removal of the Factory Integrated Source | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-24-2010 12:44 AM |
| Painting... | naossoan | Cosmetic Modifications (Exterior/Interior) | 9 | 05-17-2009 11:25 PM |
| FS: Badge Painting Service (Two Tone available!) | Corzy | Items for Sale by private party | 25 | 03-13-2009 11:55 AM |
| DIY: Painting Factory Brake Calipers | redyaris | DIY / Maintenance / Service | 38 | 05-26-2007 08:47 AM |
