Old 03-14-2012, 01:52 AM   #3
Jason@SportsCar
Originally Posted by CoryM View Post
Probably not much help but I'm running in HS so set camber to the maximum legal spec (-0.92° iirc). Tire's are wearing reasonably well from autoX so it probably doesn't need much more for a mild car. I haven't fiddled with toe at all.
Someone must make a camber/caster plate? If not they aren't hard to make. Some measurements and a local machine shop should get you sorted. I love lots of caster in RWD cars but have never played with a FWD before.
Is .92 all you could get out of the Toyota crash bolts? The rules limit the method and parts you use to gain camber, but the stock class rules do not limit you to max factory spec.
Front end alignment specs for lowered car JTDBT903 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 05-24-2011 09:59 PM
Alignment Question gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-16-2009 10:35 AM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
Question: alignment setting for a daily drive and track car? Trish Performance Modifications 4 06-15-2009 12:04 PM
Alignment specs for 08 LB? detroiter DIY / Maintenance / Service 5 04-06-2009 01:56 PM
