Old 03-14-2012, 01:08 AM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Alignment Specs Question
To the AutoX'ers out there what alignment specs are you guys running. My thoughts are to leave the rear in spec to help it rotate a bit and run the front at -1° - -2°. Since I haven't found a way to increase caster its going to say stock.
Old 03-14-2012, 01:44 AM   #2
CoryM
Drives: 2009 5-door, 5-speed
Probably not much help but I'm running in HS so set camber to the maximum legal spec (-0.92° iirc). Tire's are wearing reasonably well from autoX so it probably doesn't need much more for a mild car. I haven't fiddled with toe at all.
Someone must make a camber/caster plate? If not they aren't hard to make. Some measurements and a local machine shop should get you sorted. I love lots of caster in RWD cars but have never played with a FWD before.
Old 03-14-2012, 01:58 AM   #3
Jason@SportsCar
Caster is not critical, if you are turning the wheel to the point that caster is taking over you are doing it wrong.
I would not even consider less than -2 as a starting point. We have -2.5 on the Bspec car (rules limited) and -3.2 on the Prod car. Rear is stock on all of our cars.
Old 03-14-2012, 02:30 AM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
I spoke briefly with the chassis engineer helping me out about increasing caster, he though it should provide a small benefit but it would likely not be noticeable.
Coming from RWD cars with crappy front suspension adding lots of caster was a critical change that had to be made in order to get the car to turn in.
Old 03-14-2012, 02:49 AM   #5
Jason@SportsCar
Whiteline offers a +/- .5 caster bushing. But I would spend my time and money on other parts.
Old 03-14-2012, 02:52 AM   #6
Jason@SportsCar
Is .92 all you could get out of the Toyota crash bolts? The rules limit the method and parts you use to gain camber, but the stock class rules do not limit you to max factory spec.
Old 03-14-2012, 10:18 AM   #7
NJ Drive
Drives: 2012 Yaris SE
I'll let you know shortly how much front camber can be had with the thinnest factory crash bolts for Yaris. As far as caster goes, there's always a little 'fudge' in the subframe. Loosen all the subframe mounting bolts, push/pull the subframe towards the front of the car, and lock it down. Alignment will be necessary of course if you found that you moved it a lot.
NJ Drive is offline   Reply With Quote
Old 03-14-2012, 12:27 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
After a bit longer talk with the engineer his opinion is to not bother adjusting caster since its not going beneficial.
Old 03-14-2012, 07:41 PM   #9
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I run -2.7 degrees in the front, -1.1 in the rear, .15 toe in per side on rear ( yes I did adjust rear... With feeler gauges in between hub and beam flange) . Rear is considered to be within factory spec though.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 03-14-2012, 10:57 PM   #10
CoryM
Well, I asked and was told to keep it w/i the stock specs. The 2012 rulebooks reads:
" Both the front and rear suspension may be adjusted through their
designed range of adjustment by use of factory adjustment arrangements
or by taking advantage of inherent manufacturing tolerances.
This encompasses both alignment and ride height parameters if such
adjustments are provided by the stock components and specified by
the factory as normal methods of adjustment. However, no suspension
part may be modified for the purpose of adjustment unless such modification is specifically authorized by the factory shop manual for
non-competition purposes.
Unless I am missing something, the bold part means in stock class one needs to stay with in the stock specifications.
Doesn't really matter as I think I only have one more event in HS. After that it's STF.
Cheers.
Old 03-15-2012, 12:19 AM   #11
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
If I were you, I would get a smaller diameter bolt ... Say 2mm smaller. Install in top strut pinch flange hole, and set it in. Or shave down the shaft of the oem bolt and do the same. Hehe
Ptuning.com
Old 03-15-2012, 12:49 AM   #12
Jason@SportsCar
Cheers.
You should have kept reading :
13.8.E. If offered by the manufacturer for a particular model and year, the
use of shims, special bolts, removal of material to enlarge mounting
holes, and similar methods are allowed and the resulting alignment
settings are permitted even if outside the normal specification or
range of specifications recommended by the manufacturer.
If enlarging
mounting holes is specifically authorized but no material removal
limits are specified, material removal is restricted to the amount necessary
to achieve the maximum factory alignment specification.
Order the smallest set of Toyota bolts for the Yaris and max it.
Old 03-15-2012, 09:13 AM   #13
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Does the dealership install front camber bolts if need be? We do all the time but I don't work at a dealership lol. I'm just curious, if anyone knows.
Ptuning.com
Old 03-15-2012, 11:26 AM   #14
Jason@SportsCar
Yes. Although it is likey rare. They would rather find out why the alignment is out of range and replace the part that generates more revenue.
Old 03-15-2012, 03:25 PM   #15
NJ Drive
Here are the part#s for those who are interested:
90109-15002, 13.9mm
90109-15003, 13.3mm
90109-15004, 12.4mm
Just keep in mind that while using these bolts, there is a risk that they'll slip out of adjustment under high load conditions.
Old 03-15-2012, 03:31 PM   #16
xnamerxx
0-60 in slow
xnamerxx's Avatar
Thank you. I haven't had much luck in finding correct Part#s.
Old 03-15-2012, 10:45 PM   #17
CoryM
If enlarging
Not sure how I missed that... besides being tired and stupid. Thanks.
I didn't really look too hard at the Stock rules last night to be honest. Was more interested in STF rules. Trying to not spend money on the Yaris (daily driver) and get the project car done instead. Not sure what I would throw at the Yaris besides tires and align. Maybe a seat so I can left foot brake (instead of using my left leg to brace myself against the door). And lighter wheels... and.... arg!
Cheers.
Old 03-15-2012, 10:46 PM   #18
CoryM
btw, all the bolt P/N are in the service manual if it helps.
Cheers.
Front end alignment specs for lowered car JTDBT903 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 05-24-2011 10:59 PM
Alignment Question gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-16-2009 11:35 AM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 08:01 AM
Question: alignment setting for a daily drive and track car? Trish Performance Modifications 4 06-15-2009 01:04 PM
Alignment specs for 08 LB? detroiter DIY / Maintenance / Service 5 04-06-2009 02:56 PM
