Old 03-22-2012, 08:22 AM   #1
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Made A big move yesterday and cranked up the turbo to 12psi. Hade to make a competely new map for my FIC. Old map was only good to 10psi. Its was running VERY STRONG for about an hour of very hard driving. Then I noticed the AFR's were getting a little lean. I will do some retuning if possible. I may need more fuel system upgrades at this power level. Possibly new rail with a return line or even lager injectors? The good news is I am no longer using that jimmy rigged pull spring on my wastegate as my boost controller.
pimp my yaris is offline   Reply With Quote
Old 03-22-2012, 05:56 PM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Before you continue do a compression test so we can see what it is before 12. Your rods are goona be the first thing to go. Careful you don't burn up the exhaust valves that can make it show lean sometimes. And Dyno that thing so you can brag about it
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
