Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
My leads on my multimeter were too thick to make contact with the ECM connector and I must not have noticed it last night. Anyways, I just redid everything and here's what I got:
Check for open: C26-3 to C20-118 = 0.2 to 0.6 ohms C26-2 to C20-116 = 0.3 ohm Check for short: C26-3 to Ground = No Reading C20-118 to Ground = No Reading For the grounding point I used the one on the driver's side shock tower and the negative terminal that goes onto the battery. I'm guessing that my mechanic must have knocked a wire loose somewhere? |
#2 | |
| Compilation of Yaris TSBs | eTiMaGo | DIY / Maintenance / Service | 72 | 07-04-2024 10:36 AM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| transmission light | confused | General Yaris / Vitz Discussion | 3 | 01-22-2011 07:02 AM |
