Old 04-01-2012, 04:57 PM   #16
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
My leads on my multimeter were too thick to make contact with the ECM connector and I must not have noticed it last night. Anyways, I just redid everything and here's what I got:
Check for open:
C26-3 to C20-118 = 0.2 to 0.6 ohms
C26-2 to C20-116 = 0.3 ohm
Check for short:
C26-3 to Ground = No Reading
C20-118 to Ground = No Reading
For the grounding point I used the one on the driver's side shock tower and the negative terminal that goes onto the battery. I'm guessing that my mechanic must have knocked a wire loose somewhere?
heeroyuy01195 is offline   Reply With Quote
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
transmission light confused General Yaris / Vitz Discussion 3 01-22-2011 07:02 AM
