Old 04-04-2012, 10:05 AM   #1
kadir2538
Drives: yrais 2008 hatchback
but, i checked it has switch of the cluch. can you tell me what it means?
and cen you explain how to take air bag out. cos it has only one hole.
and there is no any screws in that hole.
kadir2538 is offline   Reply With Quote
Old 04-04-2012, 11:46 AM   #2
On a cruise control equipped one there will be two separate switches on the clutch. The one that is there now, keeps the car from starting unless the clutch is fully depressed.
The definite test to verify if your car can have OEM cruise control is to check the voltage on the ECM pin 40 of connector A21 (my DIY shows the detailed location of that pin). If there is 12 V on that pin with the ignition in the ON position then the ECM supports cruise control. If you do not see 12 V on that pin, then it does not.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
