Old 04-05-2012, 01:52 PM   #1
They are used to tune the suspension, you can add pre-load to your front sway bar, for example. The Heim joints alone are an upgrade from the stock joints, so if yours are indeed shot (likely at that mileage with rubber parts under the car), now is a good time.
Old 04-05-2012, 02:54 PM   #2
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Thanks for that info - how well do you think they would hold up to winter with a lot of salt on the roads? Better than stock?
devinlamothe is offline   Reply With Quote
Are the Prius connecting rods good for turbo application?? monchyxb Forced Induction Forum 6 12-10-2014 04:00 PM
how do you tie down a yaris cherry tomato General Yaris / Vitz Discussion 7 01-15-2011 04:26 PM
Con rods and Pistons leinadeb Performance Modifications 4 05-23-2010 07:30 PM
How To Remove Trunk Torsion Rods? Kaotic Lazagna DIY / Maintenance / Service 3 09-29-2009 12:09 PM
GI: 1NZ-FE Forged Rods Nexus1155 Forced Induction Forum 41 03-21-2009 03:29 AM
