Old 01-13-2011, 05:19 PM   #1
cherry tomato
Drives: 2010 yaris
how do you tie down a yaris
I have a 2010 Yaris 4dr hatchback. I am in Georgia and it is in Arizona so I can't get under it to check it out.
I just bought a 24ft enclosed car hauler trailer and I am going to put the Yaris in it when I get back to Arizona and transport it to California.
How do I tie down the Yaris?
Are there multiple tie down points underneath and if so what kind of fittings does it use?
cherry tomato is offline   Reply With Quote
Old 01-15-2011, 12:17 AM   #2
YAR1S
YAR1S's Avatar
i know there are two odvious tie down points in the rear. very easy to spot, as for the front I am not sure.
-Jen <3
Old 01-15-2011, 01:16 AM   #3
cherry tomato
Drives: 2010 yaris
Are they slots in sheet metal that need those special fittings or loops that hooks will fit on?
All I know is the front has a little plastic piece that pops off and a long eye bolt threads into there.
Old 01-15-2011, 08:06 AM   #4
When I picked up Crashy with an open car trailer, I tied her down using a set of tie-downs that I picked up at a local auto parts store, using the two rear holes and the bottom of the A-arms on the front. I wanted to use two points on the front, which is why I went to the A-arms rather than using the two hook.
The straps that I bought were rated for 3000 lbs each and had rubber coated hooks. They are identical to this set from Northern Tool:
http://www.northerntool.com/shop/too...4934_200344934
Old 01-15-2011, 11:03 AM   #5
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
marry another yaris and have kids?
ohhhhhhh
yea what CTscott said....
http://www.4055design.com
Old 01-15-2011, 02:23 PM   #6
cherry tomato
Drives: 2010 yaris
Would those straps with the double hooks fit?
I was leaning towars ones like these if they fit.
http://www.northerntool.com/shop/too...4936_200344936
They have them at home depot for 14bucks each.
Old 01-15-2011, 03:22 PM   #7
They probably would fit, but uncoated hooks may scrape the paint off.
Old 01-15-2011, 04:26 PM   #8
nemelek
DWEED
nemelek's Avatar
Check the tension every so often during the trip.
