Old 03-18-2007, 12:42 PM   #19
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
A little water won't hurt the engine. People run water/meth injection all the time. What would hurt the engine is if the entire filter was submerged in water. That could cause hydro-lock which can cause permanent engine damage.
EDIT: You will have to check your filter more often to make sure it doesn't get too dirty.
Dragonacc is offline   Reply With Quote
Old 03-18-2007, 12:54 PM   #20
ToTo
ToTo's Avatar
Drives: Toyota Yaris T SPORT
How about from just washing your car? The only main thing to worry about is not to submerge it in water? I also heard of "dry filters", which won't mess up the MAF sensor, those don't need cleaning, right?
ToTo is offline   Reply With Quote
Old 03-18-2007, 12:58 PM   #21
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Dry filters are the rage now because of marketing. Yes, they do require special cleaning as well.
A correctly cleaned and re-oiled filter will not harm your MAF or engine. K&N's been in business for over 25 years, just to name one oil backed filter company...
Getting either type of filter wet will not cause an engine to lock up. Its when the filter gets submerged and the engine is running and sucks up a bunch of water.
Old 03-18-2007, 01:00 PM   #22
well, if you wash your car by driving it into a swimming pool with the engine running, then you'll have a problem
As Dragonacc said, a little water getting in the intake should not be a problem, the filter should be able to stop most of it, then the rest would evaporate with the heat. The hydrolocking problem occurs when your intake sucks up water instead of air.
Imagine you have a straw in your mouth and you are sucking air. when you put the straw a little bit into the water, but you are still able to suck air, the water will not go up much. But once you submerge the hole completely, then water will rise up. Same thing with an engine, if you get liquid water into your cylinders, then you're in deep deep trouble.
Old 03-18-2007, 01:02 PM   #23
Chris07LB
Chris07LB's Avatar
Yes, picture a porn star going for the happy finish on a 12" dong... same thing.
Old 03-18-2007, 01:04 PM   #24
how very... visual...
Old 03-19-2007, 11:54 AM   #25
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
Originally Posted by Vic-2NZFE View Post
That’s funny man, I though the Yaris 1.5L had 108 HP’s on its stock form
108 to the flywheel- we're actually pretty lucky that ninety-something of them make it to the pavement. Drivetrain loss is ususally a bit more on most FWD vehicles. It's even worse on RWD cars.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 03-19-2007, 01:55 PM   #26
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Yes, on our cars there is very little drivetrain weight to get moving, and electric power steering helps keep losses pretty low.
Old 03-21-2007, 02:26 AM   #27
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
ooooooooooo that sounds hot.....anymore performance noise to my car and it will wake up the whole damn street....my car is already gettin complaints from the locals.....
then im gonna get it soon....yay for CAI'S!! :)
Old 03-22-2007, 10:50 PM   #28
Yarismatic
Drives: 07 Yaris S
you have mean neighbors :)
Yarismatic is offline   Reply With Quote
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
Reviews of Weapon*R Intake system.. WRLEO Performance Modifications 6 02-20-2007 10:12 PM
intake question and suggestions Adriaan Performance Modifications 2 01-31-2007 04:54 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
