Old 03-18-2007, 01:00 PM   #1
well, if you wash your car by driving it into a swimming pool with the engine running, then you'll have a problem
As Dragonacc said, a little water getting in the intake should not be a problem, the filter should be able to stop most of it, then the rest would evaporate with the heat. The hydrolocking problem occurs when your intake sucks up water instead of air.
Imagine you have a straw in your mouth and you are sucking air. when you put the straw a little bit into the water, but you are still able to suck air, the water will not go up much. But once you submerge the hole completely, then water will rise up. Same thing with an engine, if you get liquid water into your cylinders, then you're in deep deep trouble.
Old 03-18-2007, 01:02 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Yes, picture a porn star going for the happy finish on a 12" dong... same thing.
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
Reviews of Weapon*R Intake system.. WRLEO Performance Modifications 6 02-20-2007 10:12 PM
intake question and suggestions Adriaan Performance Modifications 2 01-31-2007 04:54 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
