Old 04-16-2012, 03:02 AM   #1
theeggrocks
Drives: 2007 HatchBack
Originally Posted by mazilla View Post
Sounds like OCV or oil control valve...they run about 100.00 from the dealer. People have a tendency to break them when working on the belt.
Does it look like this?
http://www.yarisworld.com/forums/showthread.php?t=9364
Thanks. I've searched all OEM sites, cannot for the life of me find this damn thing. I need it something terribly. I have a Infiniti G37S to drive to work, but it likes gas alot more than my mighty 180k + miles EGG. Anyone know the part #? or have any information to help? My dealers are all dumb. So I see this being a problem.
theeggrocks is offline   Reply With Quote
Old 04-16-2012, 03:06 AM   #2
theeggrocks
And no, it does not look like that at all. It looks as if it is directly above that. It has a plug so I know it has a coil on it. It has a spool with a spring return on it. It looks as if it ports oil somewheres different when the coil is energized. The OCV isn't plugged up electronically is it?? Doesn't look like it per the drawing.
Thanks
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Engine Run-on changing 1st/2nd Gears Ferret_san General Yaris / Vitz Discussion 4 09-06-2007 12:21 AM
Does the Yaris' engine have a timing chain or belt? grampi General Yaris / Vitz Discussion 8 05-12-2007 03:59 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 10:20 AM
