#1 | |
![]() Drives: Toyota Yaris 1.5 M/T '06 Join Date: Oct 2009
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
Not to hard. You must remove right front wheel. Then remove the bolt on the spindle that clamps the lower ball joint to the spindle. Then you must remove the nut that holds the axel in the center of the front hub. I believe its 30mm and must be a twelve point socket. Then slide the axel out of the front hub and slide the ball joint out of the spindle. Then you can pull the rotor hub and caliper can be pulled out of the way and tied up. Then using a pry bar you can pop the axel out of the transmission. Drain transmission fluid out first or it will be messy. Muake sure if the axel needs to be hammered out of the front hub the threads are not damaged. Air tools and a compressor make this job much easier.
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
