#1 | |
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
You're also putting additional wear on the brakes too since you are losing any compression braking effect. But its your car so go nuts! |
OH GEZUS, NOT THIS THREAD AGAIN!
NOOOOOO
#3 | |
Only Happy When it Rains
Colin Chapman disciple |
#4 | |
Even the sticky thread in the FE forum says to leave it in gear?
![]() ![]() Drives: 2008 XP9 by Sparco Join Date: Nov 2011
here we go again. There are only two instances where leaving the car in gear will get you better gas mileage, if you are going down a steep enough hill that the car keeps the acceleration anyways, or if you are slowing down to a stop anyways. On a flat road leaving the car in gear will get worse mileage than putting it in neutral will, because you will have to hit the gas pedal more with the engine sucking the energy out of your forward momentum.In reality a combination of both is the best to get the best gas mileage, depending on the situation you are in and the traffic, etc.
#7 | |
![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2011
this is a pretty narrow minded way to look at this, and may encourage people to look at this the wrong way let me re-word what you're saying: always leave the car in the most optimal gear, except for when you're just about to go below 1000PRPM in first and stop. doing this, will ensure you will have the best MPG possible, as being in neutral never helps your MPG |
| Q: when shifting into neutral... clutch? | yarisugi | General Yaris / Vitz Discussion | 31 | 04-19-2012 10:51 PM |
| 8.9 Earthquake off the coast of JDM land ..ie Tsunami! | rningonfumes | Off-topic / Other Cars / Everything else Discussions | 28 | 03-25-2011 09:59 PM |
| Coasting in neutral | bankrobber | Fuel Economy Forum | 9 | 03-11-2010 03:55 PM |
| So Close!!!! | aclark246 | Fuel Economy Forum | 13 | 06-07-2009 10:02 AM |
| The Official Having A Bad Day Thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 7 | 11-15-2008 08:38 AM |
