Old 04-23-2012, 01:08 PM   #1
Sparcoboy
Drives: 2008 XP9 by Sparco
Originally Posted by jayeh View Post
Huh?
Even the sticky thread in the FE forum says to leave it in gear?
You are correct, why? is wrong :D
Sparcoboy is offline   Reply With Quote
Old 04-24-2012, 04:57 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
here we go again. There are only two instances where leaving the car in gear will get you better gas mileage, if you are going down a steep enough hill that the car keeps the acceleration anyways, or if you are slowing down to a stop anyways. On a flat road leaving the car in gear will get worse mileage than putting it in neutral will, because you will have to hit the gas pedal more with the engine sucking the energy out of your forward momentum.
In reality a combination of both is the best to get the best gas mileage, depending on the situation you are in and the traffic, etc.
Colin Chapman disciple
Old 05-01-2012, 11:58 AM   #3
nopk
Drives: 2007 Yaris Hatchback
this is a pretty narrow minded way to look at this, and may encourage people to look at this the wrong way
let me re-word what you're saying:
always leave the car in the most optimal gear, except for when you're just about to go below 1000PRPM in first and stop.
doing this, will ensure you will have the best MPG possible, as being in neutral never helps your MPG
nopk is offline   Reply With Quote
Q: when shifting into neutral... clutch? yarisugi General Yaris / Vitz Discussion 31 04-19-2012 10:51 PM
8.9 Earthquake off the coast of JDM land ..ie Tsunami! rningonfumes Off-topic / Other Cars / Everything else Discussions 28 03-25-2011 09:59 PM
Coasting in neutral bankrobber Fuel Economy Forum 9 03-11-2010 03:55 PM
So Close!!!! aclark246 Fuel Economy Forum 13 06-07-2009 10:02 AM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
