Old 04-25-2012, 09:52 PM   #1
^ Nice install, and I like your mod.
As long as the bracket is firmly attached to the beam axle, there is no "correct" tension. If the bushing is installed so that the bar is just held firmly in place, it will perform its function, which is to allow movement but resist twisting. For example, the Ultra Racing bar, which works quite well, isn't attached to the axle at all.
But, I'll say it again: I like your mod and it would be cool if they made it that way.
Old 04-26-2012, 12:35 AM   #2
Ratz
Ratz's Avatar
Drives: 2011 Yaris 4 Dr. Sedan
Thanks for the kind word. Sometimes striving for perfection drives me crazy.
That is why I am so grateful to have purchased the Whiteline bar which includes the bushings attached to the beam axle. Most automobiles had these bushings in the past. I think it is more solid design. I am sure the supplied “U” clamps would work just fine, but since I have the capability in the shop to improve it, then why not?
I am also planning to change the attachment to the outer hole as I find the stiff setting on the inside hole to be to much as when one side wheel hits the bump on the road the force is transmitted aggressively to the other wheel, Hence giving me a feeling of overinflated tires. Nice to have the adjustment.
Ratz
Cleverly disguised as a responsible adult.
Ratz is offline   Reply With Quote
TRD rear sway bar? Lewis DIY / Maintenance / Service 26 09-10-2013 02:10 PM
Yaris Rear Sway Bar Install ? Spork Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 03-20-2012 09:17 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
WTB Rear Sway Bar nick.dollimount Willing to Buy by private party 2 05-27-2010 02:44 PM
rear sway bar needed vten Willing to Buy by private party 11 11-22-2009 11:50 PM
